![]() | Home > Technical (L322) > Fill plug gm box 03-TD6 :censored: |
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 134 ![]() ![]() ![]() |
If you mean that the hex head of the fill plug has rounded off, I used a 17mm Irwin bolt extractor to remove mine. |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
There are kits available to repair, here’s a link to one on a popular auction site…
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Looks like the filler plug will be a bit hard to reach, he may have to drop the box etc to gain access... Also you will need the sump off to clear swarf from recutting the threads, all in all not a quick or easy job...
Thanks Pete I see what you mean….not easy at all. ______________________________
Excellent for the drain plug which is the most commonly abused one...
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
Thanks for the extra tips on how to get the |
