![]() | Home > Technical (L322) > Blue smoke on acceleration after changing oil cooler seals? |
ChurchMuch Member Since: 07 Apr 2025 Location: Nairobi Posts: 1 ![]() ![]() ![]() |
This sounds like a leaky injector.
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 52 ![]() ![]() ![]() |
Check the leaf spring which sits under the oil filter make sure it’s seated properly think it’s the same oil cooler as on the 4.4 2012 Westminster 4.4 tdv8 |
3mile3llis Member Since: 24 Mar 2025 Location: West Sussex Posts: 3 ![]() ![]() ![]() |
Funnily enough I am currently working on replacing the seals on the inlet manifolds due to oil leaks and it looked like there was leaks from around there. Hopefully when I finish the job it might cure the other issues. |
So I have heard about this before but can’t find anything underneath my oil filter housing. Is it missing completely or is the 3.6 different to the 4.4?
Looks different from the 4.4 on the actual filter element dose it have anything sticking out from the bottom to plug the drain hole 2012 Westminster 4.4 tdv8 |
To answer my own question yes the filter for the 3.6 dose have a protrusion on the bottom of the filter to plug the drain hole. Sorry for wasting your time hope you get it sorted 2012 Westminster 4.4 tdv8 |
