Home > Technical (L322) > Water in spare wheel well
WheelNut
Canada 2006 Range Rover HSE 4.4 V8 Alveston Red
Hey guys,
I'm having water infiltration somewhere in the rear of my L322. It pools in the spare tire well. I'm having a hard time ascertaining exactly where the water in getting in though. There is nothing wet in the upper region of the hatch or tailgate. The only moisture is right near the bottom of the tailgate and there is water visible near the tailgate to load floor flap, as well as underneath that area in behind the sheet metal. I've pulled the drain plug for now to help alleviate the water build up. My amp and other electronics on the left and right side of the trunk/boot are all dry.
What signs should I look for that are indicative of a leak in the hatch surround seal (#6), and what would indicate the lower hatch seal (#7) is leaking? Both seals appear to be clean and unharmed.
I also read an old thread about water getting in through the bolts that secure the tow bar/recovery hook structure to the rear of the body. Any suggestions on how to test for this?
We have been getting a lot of rain lately, so I haven't been able to do any targeted water flow testing with the garden hose yet, and really I wouldn't even know what to look for at this point anyhow.
Any advice is appreciated!
 2006 Range Rover 4.4L Gas
2006 BMW 330i 6MT
2024 Mazda CX-5
Post #714827 25th Mar 2025 1:22am
Tiprat
I had similar problems when I first got our RR, I eventually tracked it down to the water seal around the whole hatch. It was getting under the metal that holds it onto the thin metal surround. The quick cost effective solution for my issue was to get some "gutter sealant" from any of the many sources ie eBay Screwfix ect ect apply the seal into the recess of the boot seal and reseat it all the way round applying even pressure, then where the two ends meet I added a bit more just to make a water tight seal, that was at least 4 years ago and I have never had another leak.
Hope this helps.... Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #714829 25th Mar 2025 2:07am
WheelNut
I like the idea. I’ll give it a go and see if it works. Nothing to lose really. 2006 Range Rover 4.4L Gas
2006 BMW 330i 6MT
2024 Mazda CX-5
Post #714830 25th Mar 2025 4:53am
jamiej
Have you checked that the leak is not from the rear wash jet?
Post #714833 25th Mar 2025 7:26am
Dolphinboy
mine is similar vintage and it was the welds by the upper hinges.
https://www.fullfatrr.com/forum/post709591.html#709591
this may also be of use.
https://www.fullfatrr.com/forum/topic45266.html
Post #714864 25th Mar 2025 1:36pm
WheelNut
I'm getting water in the rear even when I don't drive the RR. The water in the tire well doesn't feel soapy or anything either. 2006 Range Rover 4.4L Gas
2006 BMW 330i 6MT
2024 Mazda CX-5
Post #714940 26th Mar 2025 4:21pm
Range Rover L322
1) Fit new tailgate aperture rubber. Ensure to fit it accurately - there is a variation in density where the lower tailgate closes. Make sure to get it right the first time. Using silicon on an old rubber doesn't work. They often leak along the top where they stop sealing, then the water runs down the inside... and ends up in the wheel well. New ones come full of putty. run your hands along the whole thing and find the side bits.
2) Silicon the Upper Tailgate Hinge Welds.
3) Do the showercap mod (and read this thread as it gives other insight into the issue as a whole - because the next thing that is going to happen is not just a wet boot but your Parking Assist Module will stop working) https://www.fullfatrr.com/forum/topic58516...p;start=15
4) A few of us use PTFE Teflon tape on the Upper Tailgate bump stops, if you want to be really complete!
It's most likely the aperture rubber...
Good luck!
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #714955 26th Mar 2025 10:36pm
WheelNut
Update: I added some window sealer (seems like mastic type goo) to the rear channel of the hatch seal (#6 in the diagram in my first post). This ensured no water was sneaking behind the seal and getting into the body seam. I also added a heavy layer of silicone oil to the sealing surface of #6 and #7. The boot is now dry and has survived a number of heavy rains with no leaks. The silicone oil seems to have rejuvenated the rubber material somewhat. I'd say that a failed #6 hatch seal was the culprit. I considered replacing the whole #6 seal, but it costs nearly $300CDN with shipping and tax, so I figured I'd use what I had in the garage to get me by for now. I'll see if the leak returns with the heavy rain this fall and if it does I will replace the seal and put this to rest, but for now it is working. 2006 Range Rover 4.4L Gas
2006 BMW 330i 6MT
2024 Mazda CX-5
Post #717357 4th May 2025 5:01am
Fits
Germany
In my case, it was the right adjusting screw of the upper tailgate. Apply some sealant to the thread.
Post #717391 4th May 2025 5:21pm
