|  | Home > Technical (L322) > car wont turn over! |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | That would be my best bet too - something at the starter motor .
|  1st Jun 2012 9:07am |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | Also check the battery lead clamps on the battery.  Check if they are loose and check for corrosion on the clamps/poles. Clean the inside of the clamps (fine sandpaper and cloth) and the outside of the poles and put a thin layer of vaseline on it (to prevent future corrosion).  Check all the earth connections, especially the bigger ones, take them off, clean them and put them back with some contact cleaner or the likes to prevent corrosion.  A little resistance with 12 Volts can cause a big voltage drop. MY 2010 5.0 SC Galway green and sand interior!!
|  1st Jun 2012 11:49am |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
