Home > Maintenance & Mods (L405) > Adblue injector issues
Afternoon all, I’ve been chasing an intermittent issue with the Adblue system and ‘think” I might have a faulty DEF injector. I’m now seeing the dreaded countdown to not starting message, which I’ve had before but mysteriously disappeared a few times, but now it seems more permanent.
I have loads of the usual DEF type fault codes but I think I have ruled out the following
1. The injector was slightly blocked, so it was cleaned and the problem cleared up for a few weeks.
2. Checked the voltage going to the injector and it seems fine, as broken wires feature a lot in these issues.
My latest test was to see if the injector was working properly by applying 12v to it but there was no “click” as I was expecting, so my current theory is that the DEF injector may have failed completely but having removed it, I noticed that the Adblue feed pipe was totally dry, which surprised me, as I was expecting some residual fluid to be present.
My question is, would a failed injector mean there would be no Adblue fluid in the feeder pipe, or is that more likely to indicate a blockage further back, or even the Adblue pump itself?
Any help or advice gratefully accepted Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #715189 30th Mar 2025 12:44pm
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
Might be of some use?
&ab_channel=O%27RileysAutos
Post #715222 30th Mar 2025 9:33pm
Thanks, I’ve watched a few of his DEF ones but this one is for DPF, which I don’t have any issues with (yet!) Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #715226 30th Mar 2025 10:36pm
baz000000
It does detail a blockage of the AdBlue line at the inlet point into the DPF.
Post #715242 31st Mar 2025 8:56am
Yes, I’ve cleaned out the injector and also the inlet it connects to. It’s wasn’t particularly bad compared to some of the videos I’ve seen on YouTube.
I think my issue now is that there isn’t any Adblue getting to the injector, or if it is, the injector isn’t firing it in to the DPF.
Cheers Got - 2017 SDV8 Autobiography in Loire Blue
Post #715315 31st Mar 2025 11:11pm
Just to finish this thread off, I replaced the DEF injector today and all the errors are gone, so hopefully that’s all sorted Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #715357 1st Apr 2025 5:24pm
SparkyMark837
United Kingdom 2016 Range Rover Vogue SE SDV8 Aintree Green
Just having a hunt around on here and think you might've had the same issue that I've now got.
Just started getting the DEF injector fault codes and having looked online was assuming that my wiring loom was damaged, but all looks good.
Did a google search on AdBlue injectors and the general consensus is that the ohm reading across the injector should be about 12-13 ohms.
When I checked mine I got 6 ohms.
This would tally up with the open circuit errors I'm getting but was just wondering whether you measured the resistance on your faulty injector before replacing it?
Post #723013 17th Aug 2025 6:46pm
