![]() | Home > Technical (L322) > Vibration when stopped in gear. |
FIREBIRDL322 Member Since: 31 Mar 2025 Location: London Posts: 4 ![]() ![]() ![]() |
Any solutions or clues on where to look would be greatly appreciated. I've plugged in my gap iid and found nothing. 2014 Range Rover Autobiography 5.0 Supercharged V8 L405 (STOLEN)
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
i cant help but try a forum search.. |
Sp00c Member Since: 01 May 2025 Location: Stoke-on-Trent Posts: 3 ![]() ![]() ![]() |
I had the exact same issue!
Thank you very much for the suggestion. I'll have a look with my garage to get the center bearing replaced. Took the car yesterday to the same specialist and was told there is nothing wrong maybe a power steering fluid change would help. I think the center bearing is a more likely cause. I will report back once the part is replaced. 2014 Range Rover Autobiography 5.0 Supercharged V8 L405 (STOLEN)
