![]() | Home > Technical (L405) > Radar Sensor Blocked fix |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1524 ![]() ![]() ![]() |
How dirty is the bumper? Normally comes up in snow conditions or if something's blocking it, seems a bit strange, I would be more concerned you have a red triangle up!
adrianmoore2005@gmail.com Member Since: 13 May 2025 Location: Virginia Posts: 2 ![]() ![]() ![]() |
Did you fix this? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2765 ![]() ![]() |
The one on my previous L322 failed with the same message. I eventually disabled ACC in the CCF to regain the use of standard CC as the cost of a new one was prohibitive. L405 D350 SE Carpathian Grey D5 19" rims |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
I have the same issue with mine, although it works a lot of the time but fails at the exact same spot in 4 different locations.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1434 ![]() ![]() |
@comports
f4rrs Member Since: 22 Jun 2011 Location: St Albans Posts: 27 ![]() ![]() ![]() |
No, not fixed. Thinking of removing the front bumper and cleaning the sensor but haven't got round to doing it as yet. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1557 ![]() ![]() |
How much have you driven it ? I’ve found that sometimes if the vehicle has been reset or out of charge and the systems need to start from scratch then things like the radar need time to learn /reset themselves. Ie it kind of self calibrates whilst on the move V8 or else ... |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
Mine has errored twice, both times in the motorway with torrential rain.
If the L405's mounting is like the L322's then it's basically impossible for any material to get between the radar unit and the bumper because the front of the unit fits into a recess in the bumper. L405 D350 SE Carpathian Grey D5 19" rims |
jimmie Member Since: 19 Jul 2014 Location: Warsaw Posts: 201 ![]() ![]() ![]() |
if you get blocked sensor message and bumper is clean then 90% sure is wrong mounted. i.e. someone hit bumper and bent s3nsor bracket. It is really soft to protect sensor from damage. you need to bend it back straight as much as possible with hammer, set with bubble eye and wire to look straight forward, then do the calibration wit IID. ACC should again work as it should. |
