Home > Technical (L405) > Smell and smoke when hot
rattly
Hi all,
My 4.4TDV6 has started smelling of burning (oil?) after about 15 miles, and sometimes (getting more regular) has smoke coming up from the oil filter area!
There are no signs of oil leaks anywhere, and no signs of oil on the exhaust system.
I did recently have the change the MAP sensor as it was totally blocked with "gunge"!
I have had one EGR code that wont clear, but performance is perfectly normal.
I`m guessing its somehow burning gunge out of the manifold?
All input massively appreciated before i start ripping it apart!
Cheers
Roy
Post #716818 26th Apr 2025 10:05am
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Could be the oil cooler leaking or the turbo oil feed leaking these are all part of the oil filter housing.
what is the EGR code, the exhaust inlet from the crossover pipe is to the rear right of the oil filter 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #716825 26th Apr 2025 11:55am
rattly
Hi,
Thanks for the reply,,,
Egr code is P040D-00. Permanent code
Cheers,
Roy
Post #716834 26th Apr 2025 2:46pm
https://www.fullfatrr.com/forum/topic50202.html ... - .- -.
Post #716835 26th Apr 2025 2:57pm
rattly
Thanks Stan, i`ll order the tool!
Just gotta figure the smoke/leak out now!
Post #716886 27th Apr 2025 11:52am
GraemeS
Australia
An initial minor leak from the oil cooler or turbo oil feed pipe first gets onto the cross-over pipe yet doesn't show as an oil leak from underneath. Removing the cabin air intake will allow a good view of the area. L405 D350 SE Carpathian Grey D5 19" rims
Post #716946 27th Apr 2025 10:00pm
