Home > Technical (L322) > 4.4 tdv8 shut off valve replacement Secondary
Grimreaper
Ireland 2012 Range Rover Vogue 4.4 V8 Bournville
Lads ive to tackle replacing shut off valve on Turbo B
Anyone done this job before and can give me a few pointers
Where's best to access is it underneath rather than wheel arch
What has to come off from underneath, is it prop and exhaust?
Anyone got access to Topix to see what service manual procedure is? 2012 l322
TIA
Post #716890 27th Apr 2025 12:32pm
GraemeS
Australia
Are you needing to replace the turbine shut-off valve (exhaust) or the compressor shut-off valve (inlet air)? The earlier version of the compressor shut-off valve is the one that gets stuck. L405 D350 SE Carpathian Grey D5 19" rims
Post #716950 27th Apr 2025 11:08pm
Grimreaper
It's the compressor one
https://maltings4x4store.co.uk/turbo/genui...-lr066428/
I'm aware of the sticking but it's faulty and needs to be replaced
Post #716969 28th Apr 2025 9:31am
GraemeS
Australia
That's the turbine shut-off valve, not the compressor shut-off valve. L405 D350 SE Carpathian Grey D5 19" rims
Post #716974 28th Apr 2025 10:44am
Grimreaper
Wasn't sure if the correct terminology for it but that's the part I've to replace, your correct yeah the turbo shut off valve
Post #716990 28th Apr 2025 3:51pm
GraemeS
Australia
The new one may require a PCM calibration as the PCM stores the closed position which could be different to the old one. My son's 3.0 D4 needed a calibration when the turbine valve's closed position on a replacement engine didn't match the PCM which caused a restricted performance fault at idle. L405 D350 SE Carpathian Grey D5 19" rims
Post #717026 28th Apr 2025 9:59pm
RovingCanary
Good luck, I had to fix mine with WD40 and a cable tie on the hose. That was a nightmare to get to, let us know how you get on ! Hoping mine doesn't need replacing, trying to use the secondary turbo couple of times a fortnight now to avoid sticking
Post #717029 28th Apr 2025 10:45pm
