Home > Technical (L405) > How to get the back off the drivers seat 2019 AB
firstrr
England 2019 Range Rover Autobiography SDV6 Santorini Black
Hi Guys
found plenty of vids of how to get the bah panel off RR drivers seat but cant find any showing my seats. They cant be unique but I don't want to start forcing things and breaking clips etc.
Couple of pics attached, I have removed the 2 torx screws underneath and the panel moves down slightly but stops hard even pulling the bottom out.
Any info greatly received.
Post #717052 29th Apr 2025 11:11am
I'm guessing, move the seat all the way up and the backrest all the way forward, will this give more room..?? Pete
2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread-
Post #717078 29th Apr 2025 2:56pm
firstrr
Thanks H for the suggestion. I've got the seat at max height and max tilt forward. Not short of room to get at it, with the 2 torx screws removed underneath and pulling out the panel from the bottom edge, it will drop about 15mm and stop, and that's it. Given it a good weight pushing down but no go. So don't want to start using undue force and break something. The WM I have isn't for this generation/model of seat.
Still hoping somebody has experience of removing this type of seat panel.
Post #717082 29th Apr 2025 3:49pm
adara
Stop pulling, as the lateral trims need to be removed first!
Here's a very good video from powerfuluk, the removal starts at 2:25:
?si=7zaRkJV7jyCTJIsE&t=145
Post #717083 29th Apr 2025 4:09pm
firstrr
Thanks Adara. I had watched the vid previously but the lateral trims appear completely different on my seats. I've tried, gently, to tug at them but they don't want to budge. If somebody has a vid or experience otherwise I will 'grip' them - although the seat belt goes through them unlike the powerfuluk vid.
Post #717084 29th Apr 2025 4:24pm
firstrr
Couple of pics showing the lateral trims
Post #717085 29th Apr 2025 4:29pm
adara
You are right, we have the same seats, I tried to remove those covers and it’s really hard…
Post #717090 29th Apr 2025 5:45pm
firstrr
Yes, tricky one, but somebody here may know.
Post #717093 29th Apr 2025 5:57pm
adara
Someone on a different forum with a 2021: Figured it out. Two torx screws at bottom. Then the whole seat back just comes off.
He's right, I took pictures of the 2 screws under the seat.
Post #717095 29th Apr 2025 6:36pm
firstrr
Tried that first off. Removed the 2 torx screws, panel moves down 15mm and that's it. Mine does not drop off.
Post #717098 29th Apr 2025 7:13pm
adara
Just went and unscrewed the 2 torx on mine and the rear does slide until it hits the side trims. I think these need unclipping first in order to allow movement, but when I tried, one clip broke, so I lost the courage to go on...
Post #717100 29th Apr 2025 7:47pm
firstrr
Ouch! that’s why I didn’t want to pull too hard on those side trims. Need somebody who has removed these before to give a clue what to do - and what NOT to do!
Post #717101 29th Apr 2025 8:04pm
adara
I found these pictures of a rear spare, maybe they help?
Post #717107 29th Apr 2025 8:47pm
firstrr
Thanks, definitely a slide down configuration. Just need to sort out how those side trims come off without breaking all the fixings. There's bound to be a correct way rather than me just tugging and swearing!
Post #717115 29th Apr 2025 9:28pm
firstrr
SORTED
I managed to speak to an Indy and on this model of seat the side trims do NOT need to be removed to get the back panel off.
Thanks Adara for the pics of a removed panel, very helpful and match up to mine.
So the procedure is;
1. remove the 2 torx T20 screws just under the base of the panel. This allows you to pull the base of the panel out and get your hand into the left hand side moulding.
2. Grit your teeth and pull, this should spring out at the left hand side where the retainer is located 1/3rd of the way up
3. Grit your teeth again and repeat on the right hand side. The panel drops down and off.
This is the panel just removed
A few more pics showing the detail of the locators, clips.
2 lower locators
Close up of one of the spring clips - or whatever they may be called!
Overall pic of the panel
Hopefully this will help others but a footnote from the Indy, one or both of the spring clips 1/3rd of the way up on each side may break, but he says that the panel goes back in fine! Fortunately mine haven't broken. Very Happy
Post #717148 30th Apr 2025 11:35am
