![]() | Home > Technical (L405) > How to get the back off the drivers seat 2019 AB |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8790 ![]() ![]() ![]() |
I'm guessing, move the seat all the way up and the backrest all the way forward, will this give more room..?? Pete
firstrr Member Since: 27 Sep 2024 Location: Lancashire Posts: 36 ![]() ![]() ![]() |
Thanks H for the suggestion. I've got the seat at max height and max tilt forward. Not short of room to get at it, with the 2 torx screws removed underneath and pulling out the panel from the bottom edge, it will drop about 15mm and stop, and that's it. Given it a good weight pushing down but no go. So don't want to start using undue force and break something. The WM I have isn't for this generation/model of seat.
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 883 ![]() ![]() ![]() |
Stop pulling, as the lateral trims need to be removed first!
Thanks Adara. I had watched the vid previously but the lateral trims appear completely different on my seats. I've tried, gently, to tug at them but they don't want to budge. If somebody has a vid or experience otherwise I will 'grip' them - although the seat belt goes through them unlike the powerfuluk vid. |
You are right, we have the same seats, I tried to remove those covers and it’s really hard… |
Yes, tricky one, but somebody here may know. |
Someone on a different forum with a 2021: Figured it out. Two torx screws at bottom. Then the whole seat back just comes off.
Tried that first off. Removed the 2 torx screws, panel moves down 15mm and that's it. Mine does not drop off. |
Just went and unscrewed the 2 torx on mine and the rear does slide until it hits the side trims. I think these need unclipping first in order to allow movement, but when I tried, one clip broke, so I lost the courage to go on... |
Ouch! that’s why I didn’t want to pull too hard on those side trims. Need somebody who has removed these before to give a clue what to do - and what NOT to do! |
I found these pictures of a rear spare, maybe they help?
Thanks, definitely a slide down configuration. Just need to sort out how those side trims come off without breaking all the fixings. There's bound to be a correct way rather than me just tugging and swearing! |
SORTED
