![]() | Home > Technical (L322) > Hunting for gears |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 998 ![]() ![]() |
Do a little search for gearbox shudder you will get your answer if your lucky you need a gearbox flush n filter. |
Eugov Member Since: 15 Mar 2025 Location: Lancashire Posts: 10 ![]() ![]() ![]() |
Thanks. I don’t get any shudder. I’ve searched the other posts regarding this but not really got anywhere. As stated I’ve also just had the gearbox oil and filter done at a specialist with the correct ZF oil. 2011 Vogue 4.4 TDV8 Orkney Grey |
BAZ8046 Member Since: 26 May 2023 Location: Chatham Posts: 38 ![]() ![]() ![]() |
I had this recently but only in higher gears on light throttle.
Just to add I had the same fault code as well which I didn't pay much attention to as it was a U code.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3232 ![]() ![]() ![]() |
my 2011 tdv8 has done this ever since I bought it 8 years ago. never had any problems. I spoke to my indie LR specialist and he said it's not an issue, they do this. it's just the gearbox getting traction at the right moment. mine's had all the oils changed and tested, been working fine. |
Still not got to the bottom of this yet……hoping to get it booked in to see if it needs the firmware update I’ve heard some people have had success with curing the issue.
