Home > Maintenance & Mods (L405) > L405 smoke occasionally on hard acceleration
JamesMackenzie_1
United Kingdom 2018 Range Rover Vogue SE SDV8 Aintree Green
Hi all, just new on here.
I was wondering if anyone could shed some light on this subject for me. I have an 2018 L405 4.4sdv8. I’ve not long bought the car off a neighbour that mostly used it for tootling around. After a few days of gentle normal driving when I give it a boot full up to the redline I get a plume of blue smoke, although after repeating that a couple times it runs clear doing the same hard driving. Just wondering if it is an indication of something requiring attention? I understand the second turbo doesn't kick in till near 3000rpm. I'm fairly competent with the spanners but not really worked on many newer vehicles.
I've had a few land rovers over the years mostly discoverys, the last being a D4, but i have to say the comfort of the l405 is amazing.
Thanks in advance for any help
Post #717196 1st May 2025 8:35am
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Welcome!
I'm no expert but if its only been used for short trips, it could be a build up of oil soot etc it might need a few decent trips to give it a clean out and let the DPF perform a regen, fairly sure the DPF should stop any 'smoke' coming out the tail pipes are they sooted up? (my 2018 4.4 are clean) has the DPF been 'deleted'? do you have a GAP or similar to read the codes?
im sure someone with more knowledge on the subject will be along soon Thumbs Up 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #717226 1st May 2025 3:39pm
diesel Dave
Probably just a build up of excess oil in the secondary turbo and inter cooler and should burn off after a few good drag strip starts. I would suggest you also check when it was last serviced and make sure the oil level is not over full before you go ahead with the thrashing.
Post #717233 1st May 2025 4:26pm
