Home > Technical (L460) > Not unlocking
Clipper
Not unlocking
Has anyone had their car not unlock? Fob does nothing.
Have to use the key to get in and set off the alarm etc. Not ideal!
Post #717215 1st May 2025 12:40pm
is this in the same place that it normally works?
if so then it could be a low battery.
have you tried your other fob.. ... - .- -.
Post #717219 1st May 2025 1:19pm
Clipper
Thanks Stan.
Swapped the fobs and getting the same issue!
Post #717221 1st May 2025 1:48pm
time to call international rescue, or LR assist Wink ... - .- -.
Post #717227 1st May 2025 3:59pm
Clipper
I just use the manual key.
Can you call JLR Assist for such matters or do I need to take it to a dealer?
Post #717228 1st May 2025 4:03pm
if you take it to a dealer then the book in time will be around xmas.....
call LR assist and it will be dealt with fairly rapid. ... - .- -.
Post #717230 1st May 2025 4:16pm
tomo141
Definitely LR assist, I would also insist on a LR technician not AA, even if you have to wait a little longer.
Tomo ------------------------------------------
L460 D350 73 24 model FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #717393 4th May 2025 5:43pm
Bill
I had a peculiar warning on the dash about the key. Car not starting.
Long and short the car has to be unlocked using the app or the other key with the offending key in the car .
I assume it’s some sort of security issue …
Don’t get the key locked in!!!!! Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #718494 24th May 2025 4:27pm
DJIT
I think Bill might have a point here.
I recall remotely triggering the alarm once while my wife was in the car staying out of the cold at my sons footie training while i was at home.
She couldn't make the key respond until i remotely reset the car via the App.
Post #718713 28th May 2025 11:59am
