Home > Maintenance & Mods (L405) > fuel filter rubber hose
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
hi guys
just doing service and found this after removing fuel filter( see pics) please tell me this normal (i don’t think it is can’t see where it attaches to Confused
or do i need to replace the rubber tube?
thanks will
Post #717299 3rd May 2025 10:32am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
drain pipe just goes under car.
Post #717301 3rd May 2025 10:42am
will308f
ok so it just hangs there ? and it’s nothing to worry about then as i’m off to france next weekend typically lol Thumbs Up ill put it back together then …..magic
Post #717303 3rd May 2025 10:45am
diesel Dave
Yes it just dangles down so you can drain water off from the filter should it get any in it.
Enjoy France Thumbs Up
Post #717349 3rd May 2025 10:09pm
Gremlin500
Yes, as already said, this is a little-documented item that keeps us guessing, the hose on mine was very short only about 6”. Getting a container into that tiny space must be tricky to say the least!
Yeah right, only mine’s much shorter! Embarassed Laughing
Replacing the diesel filter is poorly-documented on YouTube and the internet generally, and some guys on there get stuff in the wrong sequence, and make life hard. Take a pic before you start, & remove top hoses first, there is a certain order to follow to allow best access to the next hose, and a pair of fuel hose pliers definitely makes it much faster. Next comes the latch on the band around the filter, there’s enough cable to lift the whole assembly up and easily remove the electrical plug next, before twisting and pulling off the drain cup & tube last. Reassemble in the exact reverse order, taking care to line up the “T” mark on the new filter with the pointy arrow thing on the clamp band, (in the same way as it was on the old one), -some vids on YT don’t seem to do that, and make it seem more difficult. Important to purge the new filter by cycling the ignition several times without starting the engine, otherwise an easy DIY thing. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #717351 3rd May 2025 11:19pm
will308f
cheers guys Thumbs Up ,this was the last thing i needed to sort before driving to France all sorted now
Post #717360 4th May 2025 7:39am
