Home > Technical (L405) > ADBLUE reading service menu
Kot
Did you complete the erase as per my last post? or are these images of your first read?
The first 3 DTC are all level related if you are 100% sure it's not low level or overfilled, and you have 7 litres in the tank as mentioned.
Check for loose wires/corroded connections etc on level sensor - possible level sensor failure.
The otherDTC are NOX sensor related again check wiring connections on sensors possible sensor failure or DEF injector blocked/connector issue.
There is a good thread on here regarding cleaning blocked sensor and would not hurt doing this and at same time empty tank and refill with at least 10L
https://www.fullfatrr.com/forum/topic71846...f+injector
It mentions a drive cycle after injector cleaned etc comment by Viggy17 2018 SE SDV8 4.4 Byron Blue
Post #717789 12th May 2025 10:11am
cbrman599
United Kingdom 2016 Range Rover TDV6 Barolo Black
Thanks yes these are the readings I took. I have it booked into an indy tomorrow for a look
Post #717790 12th May 2025 10:19am
Kot
Good Thumbs Up dont forget to post the findings
For interest just found this below, its the JLR fault find procedure
https://www.fullfatrr.com/gallery/albums/u...uality.pdf 2018 SE SDV8 4.4 Byron Blue
Post #717817 12th May 2025 5:39pm
cbrman599
yes will do & thanks for youre input
Post #717819 12th May 2025 5:50pm
cbrman599
Car sorted - it was adblue injector replacement - had an oil device find at same time whilst in there too and a check over the car in general.
Post #717933 14th May 2025 3:23pm
