![]() | Home > Technical (L322) > 2011 5.0 N/A no crank after engine replacement |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3315 ![]() ![]() ![]() |
Are your brakes all bled out properly?
peanutpckrupper Member Since: 27 Apr 2025 Location: Virginia Posts: 10 ![]() ![]() ![]() |
I didn't disconnect the braking system, but I'll try pumping up the brakes to see if that helps. Thanks! |
No worries, just edited my original post with a few other things too. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Gotcha I see the edits. I used the wiring harness from the original engine and the engine does crank if I apply 12v to the starter signal wire but still does not start. |
dhallworth you're my hero, I've moved on to a crank no start now. That's way easier to investigate. |
Brilliant, happy to help.
It starts on starting fluid, I need to investigate the fuel system. |
Well it kinda starts now but I didn't do anything different from before. Long crank, runs for a second or so then dies. I can rev it up just fine while it's running but it always bogs out after a second or two. The only codes I'm seeing are related to the ride height sensors which aren't hooked up. My obd scanner shows ~2100 psi of fuel rail pressure, drops into the ~2050 range while cranking and running.
That sounds very low for fuel pressure. I'll need to check mine at some point to be sure though. If the fuel pressure isn't building pressure properly then it won't try and fire.
Update - looks like your pressures are about right when cranking going by this thread here:
Turns out this is one of those cars where you need to have the airbox fully installed for it to run |
Ahh, did you not have the MAF sensors connected? That would explain it!
The sensors were plugged in, but I didn't have the center airbox installed and hooked up to the throttle body. Running all good now! Time to reinstall everything and take it out on the road for the first time. |
