![]() | Home > My Range Rover > 2018 SDV8 Woes |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
High Pressure Fuel Pump (right hand bank looking at engine) are known to be grumble on tick over, seems to be a trait.
Caulkhead Member Since: 10 May 2025 Location: Suffolk Posts: 7 ![]() ![]() ![]() |
Thank you RRS
If I were doing the one turbo, I'd do it with the engine in situ, if doing both, I'd consider pulling the engine, neither are easy in situ, but the one isn't particularly worse than the other. Pulling the engine and they both become a simple bolt off and back on job.
Thanks again. And what are your thoughts on both turbos being “gone” or at least one on its way? Pretty unlucky no?
On the 3.6 the turbos operate in parallel mode, whereas on the SDV8 they are sequential so the primary turbo does the low rpm boost with the secondary unit operating from circa 3000rpm and upwards. I've never heard of both failing at the same time (the 4.4 SDV8 in not known for turbo issues, unlike the 3.6 TDV8). It's possible if you have bigger issues like oil starvation, but I'd expect other symptoms (like a seized engine or big ends knocking) before the turbos starting showing trouble.
Thanks so much again for the reply.
Before you go any further or agree to anything I'd inspect the oil filter. Quite simply, remove the filter and cut the top and bottom of the paper cartridge off, open out the pleated filter and inspect it for metal fragments. If you find fragments then there's a good chance there's serious damage lurking that has also damaged the turbos, which is likely to mean a full rebuild (been there, done that, see my post 'All I want for Christmas') If it's clean then that's good and your back to the known problem.
Sorry for delay, was just the one turbo in the end. Anyway all repaired, did about 200 miles and then the engine went bang. What utter |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 280 ![]() ![]() ![]() |
Oh man that sucks! Is the engine totalled? Is it related to the turbo issue that you had? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
That is terrible news, I feel for you... |
That's a bummer, what's the garages stance on it? Did you/they check the filter as if it's failed within a couple of hundred of miles then there must have been something very wrong with it after the turbo replacement.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1441 ![]() ![]() |
I bought a 58k 2018 4.4 (the safe one!!) privately from I believe a very genuine gentleman, who had the car on extended warranty and serviced by the book at one LR dealer. In January the car was serviced (in my ownership) by my local LR dealer (will remain nameless, but fairly incompetent for the amount they charge). I digress, within a couple of days the service light came back, but as far as I can tell, due to LR's fairly useless information system, I had no idea what needed attention.
