Home > Maintenance & Mods (L322) > Replace sunroof [glass part] seal
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Hi,
I am looking to renew the seal around the glass part of the sunroof. It's the rubber and a sort of suede[?] one.
Is it easier to remove the glass panel to do it? [6 torx screws], or is it possible in the tilt position?.
Also when doing it is it better to pre-heat or lubricate the rubber?.
Thanks in advance
Rgds
Post #547254 15th Mar 2020 8:55pm
kevinp
My seal has holes in it and it needs changing to. Any idea on price?
Post #548551 28th Mar 2020 3:17pm
Brandon318
United States 2009 Range Rover HSE 4.4 V8 Santorini Black
Re: Replace sunroof [glass part] seal
Unnecessary quote removed
Did you ever sort this out? Need to do this on mine too.
Post #717755 11th May 2025 4:08pm
kevinp
You have to buy the glass as well. Big Cry
Post #717759 11th May 2025 5:25pm
