![]() | Home > Technical (L405) > Warning lights on |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
Sounds very much like a faulty ABS sensor. Got - 2017 SDV8 Autobiography in Loire Blue
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1525 ![]() ![]() ![]() |
Have you checked the earth strap, anything weird like one of the headlights not working? |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1441 ![]() ![]() |
Have you a code reader and read the DTC's and then reset/erased them?
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 603 ![]() ![]() ![]() |
Had the same thing on my l322 when I did the wheel bearing,I did replace the abs sensor but fault codes only cleared when I used a genuine Range Rover sensor |
