![]() | Home > Technical (L405) > No Aux battery |
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 107 ![]() ![]() ![]() |
Hope this helps
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871 ![]() ![]() |
where the aux battery 'should' be is where the capacitor is located...
RR4ED Member Since: 24 Mar 2025 Location: East Yorkshire Posts: 17 ![]() ![]() ![]() |
Thank you buddy, i been there its definitely no battery there, had one with my L494 in that location. |
Thank you, i will have another look at it. |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491 ![]() ![]() ![]() |
Have you told the car via diags box it has a new battery, stop start may not work until you do. They do sometimes reset after a while but better to reset with diags box. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1879 ![]() ![]() ![]() |
@RR4ED:
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1441 ![]() ![]() |
@Gremlin500
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
I found the CCF entry to keep it turned off as it's right royal pain! Got - 2017 SDV8 Autobiography in Loire Blue
Important to say editing the CCF doesn’t DISABLE Start-Stop (on MY17) rather it changes the default behaviour, so the centre console switch is lit up, (indicating S/S OFF) when you turn on the ignition.
Indeed, but it has the same effect as disabling it. I used to have to remember to switch it off every time I start the car. Got - 2017 SDV8 Autobiography in Loire Blue
Thank you guys, I shall leave it alone.
