Home > Technical (L322) > Shift solenoid a fault
Scotafv8
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Now then. I've a 2003 4.4 V8 petrol Vogue . I've had it for near a year and now , after about 20mins of driving and she's warm..... I get the dreaded gearbox limited operation fault . Stuck in 4th limp mode and shift solenoid open circuit fault. If I park up and leave it go back to cold it's fine. My question being.... Is this a solenoid fault or damaged loom. I've a full service kit with filter to do but debating whether to just change solenoids and fit new seals whilst I'm in there. I only bought it asca stop gap but absolutely love it. I'm looking for best options and where I can get solenoids and seal kit for valve body
Post #718013 15th May 2025 10:22pm
RRPhil
Prices for new Bosch solenoids for the 5HP24 are just crazy. Both the EDS and shift solenoids are generally very reliable so it might be better to concentrate on replacing just the faulty one if, indeed, it is a solenoid fault. What is the exact fault code that you’re getting?
The shift solenoids don’t have a seal. They’re just a good sliding fit in the valve block.
Phil
Post #718017 15th May 2025 11:17pm
Gsxr1250dave
My solenoid tested fine on mine iv been trying to sauce a loom ever since with no luck the eBay one I bought never arrived from china so the cars still laid up.
Post #718020 16th May 2025 12:59am
Scotafv8
Thanks for that. I'll go for a run and see what it is again. . There's no code now this morning. 🤦‍♂️
Phil
Post #718024 16th May 2025 9:18am
Scotafv8
Well ... I've given it a full service... Oil was dark but no debris. Magnets where just usual fur on them. Filter was dark too. Cleaned valve block best I could but still getting limp home 4th once it's up to temp with " shift solenoid 1" or " shift solenoid 1 open circuit. " Can someone please tell me which solenoid is "1"? please
Post #718315 21st May 2025 8:32pm
