![]() | Home > Technical (L405) > Some strange electronic gremlins |
ss10 Member Since: 05 May 2025 Location: Reston, VA Posts: 39 ![]() ![]() ![]() |
Haha! Dont have a wife so no, haven't seen that problem.
Have a look at this also: https://static.nhtsa.gov/odi/tsbs/2015/SB-10105660-9340.pdf |
pasha0305 Member Since: 09 Mar 2024 Location: London Posts: 16 ![]() ![]() ![]() |
Thanks! Will try this first. 2016 TDV6 Vogue SE Santorinin Black |
Well…..some interesting developments. This morning the car wouldn’t unlock from the fob! Had to use the “secret” key. Of course the alarm went off and I could only get the car to start to the electronics on stage (before the engine starts) but no further. It also kept switching off pretty much immediately.
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 883 ![]() ![]() ![]() |
Very interesting, as I encounter rather similar problems: https://www.fullfatrr.com/forum/topic73098.html |
Did you manage to get yours sorted?
Not yet—this is the worst kind of failure. The one that appears only occasionally and doesn’t trigger errors. The car works fine for days — or weeks, and then, suddenly, everything goes wrong. Steering column locks, refuses to unlock, screens starts rebooting, etc... |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
Body earths are a known and very common issue on the L405 as it ages, (I think there are 3 in total in both front wheelarches, but I can’t remember). Easy to get to. They can even visually look OK, then snap off if you try to loosen them or even just wire brush them to add some corrosion inhibitor. Before failing completely, they regularly can cause a myriad of simultaneous DTC’s anf faults. A weak battery can have quite similar effects, however, so check both.
+1 on looking at earth points in the wheel arches. Mine snapped so I botched it.
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 97 ![]() ![]() ![]() |
So, a list of annoying electrical gremlins I have encoured:
I checked the earth points on both sides. There’s only one wire attached to the right one and two to the left, both of them looking really good. I cleaned and tightened them anyway, even the three earth points under the bonnet on the right side.
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 416 ![]() ![]() ![]() |
Error 1. I think is by default as in mine when in reverse the volume adjusts the parking sensor volume. 2. Whip the rear spoiler off, there's a bunch of earth's on the one hinge bracket that can corrode. 3. I had similar in my 2014 L494 with the heated wheel, whenever I visited a local Co op convenience store most times I got back in the car the heated wheel would be on, turned out the store had one of those high frequency kid scarer devices that omit a high frequency noise that only youngsters can hear, somehow interfered with the electronics. When they removed it (as it turned out they didn't have planning permission) the problem went away!! Hope that helps!! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
