![]() | Home > Technical (L322) > L322 4.4 TDV8 Rear Engine Oil Leak (other than cooler) |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 268 ![]() ![]() ![]() |
I have exactly the same issue, although I’ve eliminated the front crankshaft oil seal and also the timing chain tensioner bolt cover.
BAZ8046 Member Since: 26 May 2023 Location: Chatham Posts: 50 ![]() ![]() ![]() |
Hi Benji,
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 841 ![]() ![]() |
Plenty of threads on this
Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 36 ![]() ![]() |
Thanks All..
Rambles if you mean the viton 0 rings for the feed on the back of the cooler I have taken a look at this and its completely dry. |
Back from the garage - my leak is the transfer box output flange seal. This chucks oil around so you’re searching all over for the culprit. A couple of hrs work if your driveshaft pops out ok.
