Home > Maintenance & Mods (L322) > Ac compressor solenoid, sticky valve replaced
s.m.
Bosnia Herzegovina
Hello,
Since i did not see.post where someone just replace valve on ac compressor, here is one Smile
If You have same problem as i did, you can just replace solenoid valve
Cost was cca 65 EUR
Job itself took 20 hours (i have done puleys, water pump and 2 belts)
Most consumin time is the third bolt behind compressor (LHD), that took half of the time. Space for hand is so narrow that i had to use camera multiple times just to see situation
New o rings on ac compressor, just to be sure no leaks there.
Ac is now working as it should.
It starts blowing cold.air in less than 30 seconds (before..few minutes or no cold air)
I had to do multiple..on/off expeeimwnts.on different rpm..so i could get some cold air
Car has 195 000 kilometers
Post #718649 26th May 2025 9:32pm
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Where did you purchase solenoid valve and o rings from? -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #718729 28th May 2025 2:44pm
s.m.
Bosnia Herzegovina
O rings were made in special workshop, where they make parts for construction/hydraulic machines
I gave them old o'rings, told thaem what i need it for and they produced it in 60 min
It is high temperature resistant silicon.
Regarding solenoid,
Thermotec
KTT060020
Price was around 50 eur
There is lot of solenoids to purchase on ebay
Post #718733 28th May 2025 3:25pm
