![]() | Home > Technical (L405) > [SDV8] Rebuilt engine won't start |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
Not aware of any other procedure for bleeding, I did the same and it started up after probably 40 secs of cranking.
szymonn Member Since: 10 Aug 2024 Location: Paniówki Posts: 10 ![]() ![]() ![]() |
I used an old trigger wheel but I'm sure that it's ok (I have a tool to check it) Of course. I Installed it using the proper tool. I getting two DTC issues First with something regarding the LIN bus and second turbocharger bypass valve. I'll poste the proper decription when I will go to the garage |
Yeahhh working! I disconnected the turbo bypass valve. THX a lot for everything |
Glad you got it sorted!! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
