Home > Maintenance & Mods (L405) > aux belt/pulleys
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
aux belt/pulleys
hi all range rover is now 11 years old with 97k and cant see anything on service records of belt or pulleys been done so intend to do them along with tensioners and water pump,was thinking also while im at it going to do the oil pump ......happy with all apart from oil pump has many ppl changed the oil pump ? and if so is it as a big a job as what it seems (wsm) or is there any work around ?
thanks will
Post #718743 28th May 2025 7:08pm
will308f
no one ever changed a oil pump ?
Post #718855 30th May 2025 5:15pm
Gremlin500
Yes! Very Happy
Well, Embarassed not quite: I had my oil pump changed which isn’t quite the same thing!
I would heartily recommend changing the oil pump every 50K miles (or with V6 models each time the toothed belt service is due).
On the V6, A genuine JLR pump is around £500 fitted (at the belt service) which equates to £10 per 1,000 miles. Peanuts. I have seen a marked reduction in trace wear metals since fitting a new oil pump, which proves at 50K miles, oil pumps are getting tired, OP is reducing, and accelerating engine wear.
A pre-emptive 50K oil pump change has 2 benefits: (1): Reducing likelihood of expensive engine failure, and (2): Much improved saleability of the vehicle.
To me, it’s an absolute no-brainer. V6 Vogue - “Less is More” - less to go wrong!
Post #718870 30th May 2025 10:40pm
will308f
hi gremlin
mines the v8 ,i did have a look in the wsm and it say about the drive shafts to be removed and also dropping the sump and a lot of other things as well ....so was hoping that someone had replaced there's and says you can do the job doing x-y-z if you get what i mean ...checked the price for oil pump as its about the same as yours was ......or is the lack of replies a positive thing and it don't need replacing unless you get issues .
Post #718878 31st May 2025 9:45am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
If you want to replace the oil pump on the SDV8 with the engine in situ then to 'do it properly' you need to remove the sump, and to remove the sump you need to remove the front diff, and to remove the front diff, you need to remove the driveshafts... You'd also need to remove the starter to be able to fit the rear crank locking tool to allow you to remove the crankshaft main front bolt.
If you do plan on doing it a genuine pump is £467.58 and you'll also need a front main seal at the bargain price of £36.94 along with a sump gasket.
I believe it can be done the 'unauthorised way' by leaving the sump in place and hoping it reseals as it's not possible to replace the sump gasket that the pump also mates to.
It's a doddle with the engine out, not a job to look forward to with it in situ though I would imagine. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #718880 31st May 2025 10:08am
will308f
Thumbs Up yea i was getting that feeling and oh yea was going to use gen range rover part ,ok as im not having any oil pump issues i wont bother and just do the rest Thumbs Up
Post #718881 31st May 2025 10:18am
Gremlin500
Wow! I had no idea it was so much trouble on the V8!
I love my V6 even more now, lol! Laughing V6 Vogue - “Less is More” - less to go wrong!
Post #718900 31st May 2025 5:45pm
will308f
lol yea its a hell of a lot work Big Cry
Post #718905 31st May 2025 7:17pm
Gremlin500
I think I may just have found a workable solution:
Buy a V6 oil pump, -attached to a V6 model FFRR, and dispose of the V8! Laughing Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #718967 1st Jun 2025 10:51pm
will308f
Rolling with laughter Rolling with laughter see i knew someone would find a work around Thumbs Up
Post #719003 2nd Jun 2025 11:16am
4RRS
I don't like to put a dampner on the solution, but it's much the same procedure for the TD/SDV6, the wsm states the sump should be removed, not saying you have to but... L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #719004 2nd Jun 2025 11:19am
will308f
@rrs ok.....when looking for videos sdv8 i did see many of the sdv6 been done and they did only remove the oil pump and replace it using approved range rover sealant hence why i asked ,and it looks like the sump gasket on the sdv6 doesn't go under the bottom of the oil pump,and if range rover just use there sealant and not a gasket then i don't know .....and i wouldn't put it past some dealers it do just that.
Post #719008 2nd Jun 2025 11:33am
4RRS
I'm sure the dealers do that, but charge against the workshop manual time, big win for them! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #719009 2nd Jun 2025 11:36am
will308f
oh hell yea big time....... and im guessing or assuming here but i bet even independent specialists do the same (sealant) job done .i have just been looking at the sump gasket and doesn't look like it actually is made to go between the bottom of the oil pump and sump so they must just use sealant as there is no gasket apart from the rubber one around the pump and the crankshaft seal (i could be wrong tho)
Post #719012 2nd Jun 2025 11:45am
4RRS
The pump should be fitted with the sump off as you are supposed to align the face of the pump and block with a straight edge, which obviously you can't do with the sump in place. I thought the gasket also fitted between the pump and the sump, but maybe I'm mistaken.
Either way, it's not a nice job! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #719014 2nd Jun 2025 12:06pm
