![]() | Home > Technical (L405) > Why only 8L of engine oil. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962 ![]() ![]() ![]() |
When I suck the oil out of my engine I typically only get about 8L so I put about 8L back in and the on screen indicator reads fullish.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1881 ![]() ![]() |
Not getting all the old oil out is the only explanation |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1441 ![]() ![]() |
Also only putting in 8L is another explanation 2018 SE SDV8 4.4 Byron Blue |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883 ![]() ![]() ![]() |
Are you getting the engine warmed up sufficient before starting sucking , much easier than trying to with cold engine.
I am doing all the right things apart from changing the filter last as I got round to thinking that it might hold a litre or so. I’m not particularly worried as even 8L of fresh oil should at least in part help with the dilution situation. Geoff |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
I've sucked it out several times and I only get 8 ltrs as well, that's with unscrewing the oil filter first and the level showing nearly full...
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 280 ![]() ![]() ![]() |
I assume you are talking about the 4.4 engine? I have just replaced my oil and got exactly 9.25 litres out and refilled it with the same. Shows as 2 down from the top of the level so not in the red. _______________________________________________
Yep just checked mine again it’s flicking between full and the one below on the oil level indicator - perfect !! |
