Home > Maintenance & Mods (L322) > Heatshield Repair Kits
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
I noticed these were appearing on EBAY more frequently so I thought I'd take a punt to see if I could use them to fix my rattling heat shields.
The steel star washers looked untreated so I painted them up in silver before fitting and then sprayed with waxoyl in situ to stave off any further corrosion although them being heat shields who knows how long that'll stay put, if it lasts 5 years I'll be happy.
About 53 mm across each disc and about 0.5mm thick. They appear to be made of quite stiff ally alloy and look up to the job..
Anyway, fixed for now, time will tell.
A.
 Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #719020 2nd Jun 2025 12:04pm
tigmutt
Hi Andy my nuts are all rusty ( so to speak) and I had to chisel em off. Do you happen to know what size thread I need to get new nuts to fit the heat shield?
Post #719416 8th Jun 2025 3:41pm
AndyRoo
Hi,
There not so much a thread as in a bolt but more like a self tapper protruding from the body.
I used the star washers from the kit topped with an M3 plastic nut, so far it seems ok.
The proper fixing is a stamped washer / nut combo similar to the link below, but I've not gone with this as I'm sure they'll just rot away as the originals.
https://www.ebay.co.uk/itm/305956693187
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #719437 8th Jun 2025 7:55pm
tigmutt
Thanks for that.
Post #719439 8th Jun 2025 8:28pm
