![]() | Home > Technical (L322) > Rear driveshaft popped out |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
Last week left the fatty at the garage for engine mounts replacement, sump plug helicoil repair, rear hub bushings and a few more things. Yesterday morning picked the car up and continued to my work. On my way home, while passing near walls, a scraping noise could be heard from the rear right but only briefly; it was then gone so I didn't think much about it.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8820 ![]() ![]() ![]() |
Oh dear, I hope it's not as bad as it looks and sounds.... Pete
Not holding my breath, Pete. Already checking diff prices online... |
The inner cv joint is indeed squeezed as the boot seems significantly compressed compared to the left side. I could try hammering the axle back in but I'd rather try to have them (the garage) make right as it certainly seems to be their doing, which I'm not at all certain they'll be taking ownership of. If I touched it myself, then they'll be literally washing their hands...So I'm having her sent over on a tow truck first thing in the morning, hoping for the best. |
To their credit, the garage fully acknowledged responsibility and repaired the damage at no cost. It is literally the first time ever that a garage assumes responsibility for something like that in my neck of the woods, and I'm really thankful and appreciative of their way of handling matters.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1553 ![]() ![]() |
That’s a decent result. It should be fine long term. V8 or else ... |
And, as if the recent cockup wasn't enough, I had to send her in again. For a pierced CV boot this time. Rather suspiciously it was the front left inner cv joint which happens to be right beneath the engine mount, which was only recently replaced. The rubber had not deteriorated or cracked, it was a damned hole! I had the axle rebooted both ends for EUR 180 though I'm beginning to think I had better booted someone's |
