Home > Technical (L322) > ZF 6HP26 - 2007 3.6TDV8
RRPhil
Although I need to look in more detail at the data for the 3 ‘judder’ runs (nothing particularly jumps out at me), I wondered if you noticed - i.e. could hear or feel - the engine speed cycling during the 10 seconds or so spent in 4th gear during the light throttle run?
Phil
Post #720752 3rd Jul 2025 5:30pm
P&D
Ireland 2004 Range Rover Vogue Td6 Sumatra Black
Thank you so much for your replies guys.
In answer to if I could sense anything on the light throttle run, not that I recall. However, I have noticed the revs doing what I would call "hunting" at some stages.
In the 3 throttle runs I did feel anything wrong. On the judder runs, the judder was very apparent, as in my 80 year old mother would have noticed something wrong.
Thanks again for the help, really appreciate it
Post #720756 3rd Jul 2025 6:13pm
RRPhil
Very strange. Considering the judder is so apparent, you would really expect to be able to see it in your three ‘judder’ runs, but it just isn’t there. You generally see a 1Hz oscillation of around +/-100 rpm in engine speed (like we saw in Gsxr1250dave’s traces).
On the other hand, you can clearly see an engine speed oscillation in 4th gear during both the light and the medium throttle acceleration runs, yet it isn’t noticeable to the driver.
Phil
Post #720838 4th Jul 2025 11:44pm
P&D
Hello guys, sorry again for delay in responding.
We drove the l322 over 500km at the weekend and I can report the following:
In 4th gear, the ossolating is noticeably there, you can hear it if listening and see it in the rev counter. It is not jarring in any way and I would say most wouldn't notice it unless pointed out.
Any ideas what this indicates?
Thanks again for reading and all the help.
Post #721448 17th Jul 2025 12:20pm
RRPhil
The torque converter lock-up clutch is in its controlled slip mode in 4th gear during your light throttle run (to prevent the transmission of torsional vibration due to the low engine speed) and should be slipping at a constant rate of around 2-3%. However, clearly the slippage is far from constant and you can see the EDS6 current cycling to try to maintain constant slip i.e. the clutch locks so it backs off the current, then the clutch starts to slip excessively, and the controller re-applies the current. This would certainly indicate a mechanical issue with the torque converter.
I personally don’t agree with the addition of a friction modifier in the fluid to ‘cover up’ a mechanical issue (i.e. it won’t put friction material back on the friction plate) but, as discussed at the beginning of the thread, it is a useful temporary technique to prove that the TC LUC is at fault.
Phil
Post #721463 17th Jul 2025 6:46pm
P&D
Thanks again Phil for your time and detailed reply.
Having read what you have said a few times, it make total sense to me now.
I have some shudder fix to hand so will add it and see what happens and report back.
If it does mask the issue, are we looking at a new TC? Perhaps the Gearbox itself is OK?
Thanks again
Post #721470 17th Jul 2025 9:27pm
RRPhil
Yes, hopefully it's just a worn lock-up clutch and you can have the converter re-manufactured and there will be no need to open up the transmission.
Phil
Post #721478 17th Jul 2025 11:22pm
P&D
Hello again all, sorry for delay again, I have just got around to adding the Shudder Fixx.
I got the gearbox up to temp, checked with IID, then added 2 shudder Fixx with some ZF oil to the box.
I took it for a 100Km trip and not only is the shudder gone, the hunting of the revs has stopped (or is not noticable) in 4th gear.
The car feels great.
What does this spell for me?
Thank you all once again for your input.
Post #722133 31st Jul 2025 1:27pm
RRPhil
It means you’ve put a band-aid on the problem i.e. you’ve treated the symptom and not the cause. Your torque converter is in need of a replacement lock-up clutch friction plate.
The friction modifier not only affects the torque converter lock-up clutch but also the main shift clutches/brakes in the transmission, too. As long as the solenoids still have some adaption range left to compensate, the controller can make the necessary adjustments. I'm hoping someone in the future will be able to take the 'before' and 'after' readings for the adaptions to see what effect the friction modifier has on the shift times and pressures.
Phil
Post #722140 31st Jul 2025 3:42pm
P&D
Thanks Phil, appreciate the reply!
I am correct in thinking an entire new TC would be the best route to take?
Shame I don't have the before adaptions logged....
Post #722142 31st Jul 2025 5:42pm
RRPhil
Yes, clearly a new converter is the best option, but I’ve also had very good results over the years from re-manufactured units, provided that the re-manufacturer has a lot of experience working on these Sachs units. This is because these converters feature a ‘captive clutch’ where the spring retainer for the LUC piston is friction welded to the centre tower.
https://www.youtube.com/watch?v=_5D6akI8DBU
This weld has to be machined off to release the friction plate and then re-welded back into position very accurately afterwards. There are relatively few shops capable of carrying out this work in the UK, but the ones that I’m aware of who do have the capability include JPAT https://www.jpat.co.uk/torque-converter-remanfacture.html, Sussex Autos https://www.sussexautos.com/pages/torque-converters and Mackies https://www.mackie-transmission.com/torque-converters.
It would be worth getting a quote to compare the cost of a new unit with a re-manufactured one.
The 3.6 TDV8 uses the Y94 torque converter.
Phil
Post #722154 1st Aug 2025 12:07am
P&D
Thanks again Phil, what you are saying makes total sense.
I am going to price a reconditioned unit from the sources you have mentioned above.
I will report back with the pricing, for reference sake for someone in the future.
I do note reconditioned units on ebay for £350 with old unit sent back.
I have seen new units on a couple of sites for €6k,or there about.
Thanks again and I will keep the thread alive when I know more.
Post #722177 1st Aug 2025 1:17pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Any suggestions also for the US - for suppliers
Hi Phil,
Id also ask you for links to any US suppliers as Im about to do the same
Thank you 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #722299 4th Aug 2025 3:55pm
RRPhil
I’m in the UK and have first-hand experience of using JPAT and Sussex Autos. If I recommended anyone in the States to remanufacture your torque converter it would just be the result of an internet search, which I’m sure you’re more than capable of doing yourself. I do know of two official ZF parts suppliers in the USA i.e. Eriksson Industries in Connecticut and The CTSC in California whom I would certainly recommend for new ZF parts, but I have no idea if they have any torque converter re-manufacturing capability. They may well know of trusted suppliers, though.
Clearly, your situation on that side of the pond is different to ours, because automatic transmissions with torque converters have been the mainstay of your car industry for decades. There will therefore be workshops/businesses who deal exclusively with torque converter remanufacture over there – which is something we just don’t have here in the UK.
I would start by contacting Eriksson Industries, if I were you: https://zftranspart.com/
Phil
Post #722323 4th Aug 2025 8:27pm
