![]() | Home > Technical (L322) > ZF 6HP26 - 2007 3.6TDV8 |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1026 ![]() ![]() |
It won't be the gearbox but the tq 1st off add x2 tubes of Dr tranny shudder fix you will be amazed |
P&D Member Since: 03 Aug 2023 Location: Donegal Posts: 21 ![]() ![]() ![]() |
Thanks for the reply.
I have been throught similar with my gearbox having completed a full refurb including new solenoids, bridge seal and tube seals plus correct fluid.
Thanks Dave.
I did all the work it's not that difficult to be honest. I think I'm 2000 miles plus with no more shudder. I will be getting the tq refurbished at some point when I can get the gearbox off. |
Thaks for the replies.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
The judder in 3rd gear up an incline will probably be caused by the torque converter lock-up clutch friction plate being worn. The torque converter can be removed, re-manufactured and replaced without having to open up the transmission (although the transmission has to come out to gain access). You can prove that it’s the LUC causing the vibration by measuring and recording live values for
Thanks very much Phil, really appreciate you taking the time to reply here, I know you are the go to in relation to these boxes so it means a lot for you to offer the advice.
Hello, so to explain my absence, I took the L322 out to do the live data logging and on my full throttle run I burst a boost hose - so between waiting on parts and having the time to do it again - I now have the results in PDF from Gap IID
Is it possible to post up the actual pdf files containing the captured measurements? Unfortunately the IIDTool doesn't line up the axes accurately enough to be able to analyse the graphs.
Thanks Phil, yes, PDFs attached here:
Hmmm, not sure what’s happened there. Usually the data looks like this:
Thanks very much for the reply Phil, really appreciate it.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 809 ![]() ![]() ![]() |
id say TC is failing |
