Home > Maintenance & Mods (L322) > Rear Shocks
NOTSHARP
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Rear Shocks
I had my car on the ramp at my local garage for a post purchase inspection, and to investigate a 'thump' noise from the rear when driving over rough road surface/potholes. The noise is from both sides, but far louder on the NS.
The car had new rear shocks fitted in May, (prior to my purchase) (MOT)) as the old ones were weeping oil.
The 'new' ones have no make/name on them. One marked L, the other R. That is all. When reversed off the ramp, over the rollers, the back end bounces noticeably.
No play in any bushes, etc. The garage is an MOT station, by the way.
I am really dubious about the no name shocks, so they will be replaced using :
Bilstein Dynamic shock absorber LR023573 and LR023580
Is this the best option, or are there good alternatives?
All responses will be much appreciated.
Steve. “He that strikes the venison first shall be the lord o' the feast.” — Shakespeare, King Lear.
2012 Vogue SE. 4.4 TDV8, Sumatra Black
Post #719772 14th Jun 2025 9:01pm
GraemeS
Australia
I had no issues with Bilstein shocks on my MY12. The first pair of rears lasted as long as the orginals and another pair has just been fitted by the current owner.
However Bilstein rear air-springs are too short for MY10-12 off-road where they burst from being over-extended and Bilstein front struts are fitted with Dunlop air-springs which didn't last long so other air-springs were fitted to the Bilstein struts. L405 D350 SE Carpathian Grey D5 19" rims
Post #719774 14th Jun 2025 9:50pm
JMC
I just replaced my (MY12 CVD) rear shocks with new (OEM) Bilsteins from Island 4x4 @ £199+vat each. Perfect! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #719777 14th Jun 2025 10:17pm
NOTSHARP
Many thanks to both of you.
Post #719780 15th Jun 2025 3:54am
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
Another vote for the Bilstein replacements from Island 4x4.
Best price around and quick delivery.
My originals were both weeping a little so I decided to get them changed out as they were only going to get worse.
Post #719816 15th Jun 2025 8:42pm
NOTSHARP
Thank you.
It would seem that the Bilstein's are the correct choice.
Post #719818 15th Jun 2025 9:05pm
mjdronfield
I too got mine from Island 4x4 a few years ago.
No issues.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #719820 15th Jun 2025 9:08pm
No answer to your current predicament as we only ever fit JLR parts, but just wanted to mention on the late model 322's all the rear shocks leak a little misting. Ive never Sean one that doesn't so... Note to later viewers of this post. Don't just change them as they look misty as they all do that Thumbs Up
Post #719845 16th Jun 2025 1:47am
GraemeS
Australia
Mine weren't misty, just worn-out. L405 D350 SE Carpathian Grey D5 19" rims
Post #719849 16th Jun 2025 5:01am
JMC
Does this mean JLR parts only, or would you go with Bilstein rear shocks, or a GKN prop from normal trade sources?
On the subject of the rear shocks, are they actually 'sided'? Different part numbers, but nothing to distinguish them out of the box. Fittings are the same and they turn 360deg, so I can't understand the two part numbers thing.
I fitted them on a 'first out of the box' basis, so it's 50/50 if I'm wrong..... Whistle The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #719853 16th Jun 2025 8:23am
GraemeS
Australia
The bush extension on 1 side only that locks into the suspension arm determines to which side the shock will fit. L405 D350 SE Carpathian Grey D5 19" rims
Post #719859 16th Jun 2025 10:27am
dingg1
Do jlr make many of their own parts? 🤔
Post #719863 16th Jun 2025 12:02pm
Pawl
LR only manufacture bodywork & assemble other suppliers parts Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #719905 16th Jun 2025 11:55pm
NOTSHARP
New shocks were fitted yesterday. The drive home from the garage is only a mile, but I noticed immediately that the clunk was absent.
I went for a drive to Elgin this morning,(70 mile round trip), and the handling is night and day different. Even SWMBO commented on how much nicer the ride is. I did not realise just how much the back end was moving around before.
Now, what's next? Very Happy
Post #720759 3rd Jul 2025 7:39pm
