Home > Maintenance & Mods (L405) > What’s happened here?
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Changing all the oils etc on my new to me 2016 and spotted this, looks like the covers have been cut away any idea why? both sides front and back, Did wonder if it was deplorable steps related but can’t see anything on the build sheet for them
Also this exhaust ‘joint’ looks factory, any idea if its repairable?
Andy 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #719881 16th Jun 2025 5:51pm
fisha
Maybe cut away on the sills for deployable steps or similar which have been removed.
The exhaust is just a clamp, you should be able to remove it (including the tab that holds it in place ) and replace it with another suitable clamp. V8 or else ...
Post #719882 16th Jun 2025 6:09pm
it was done for side steps..
i had to do that so mine would fit... ... - .- -.
Post #719883 16th Jun 2025 6:13pm
Andyyav
Appreciate the replies, I’ll see if I can find some form of clamp for the exhaust , were your steps fixed? SWMBO has hinted I should get some, our 2011 had deployable ones that worked! The D4 before that had fixed ones, I prefer the deployable ones but only when they work! 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #719885 16th Jun 2025 6:44pm
yes, fixed steps ... Thumbs Up ... - .- -.
Post #719886 16th Jun 2025 7:28pm
Keep an eye out on fleabay or marketplace for used deployable steps sets as they are often on there sir Thumbs Up
Post #719900 16th Jun 2025 11:44pm
Andyyav
Would they be an easy fit? I guess I’d need the wiring loom for them to or is ‘everything’ there somewhere hidden up? 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #719908 17th Jun 2025 6:53am
If yours had deployables fitted previously then there’s every chance the wiring is still there! Get underneath and see if there’s some unused big waterproof plugs loitering unused! If not either you had fixed fitted previously or the person who removed the steps,
removed the complete kit and caboodle.
Now, something else to consider would be. If it had fixed steps fitted previously, the cutouts will most certainly be different to deployables and visa versa! So, maybe worth checking for anymore clues left… I.E are the wiring blank grommets still fitted and is the dirt on them disturbed or not? If the latter is suggest the steps were probably fixed? Do you have a steps button down by your boot opening button? As that’s another giveaway…
Hope that all helps with your decision making process sir 👍
Post #719924 17th Jun 2025 12:31pm
Andyyav
Excellent tips thank you!
Hadn’t paid much attention to the steps button as the L322 was up by the mirror, I thought the button by the boot opener was the suspension ‘queens button’ but that’s in the usual place Embarassed
Just had a scan with the freshly delivered GAP and looks like (along with the button) it did have deployable steps!
That’s me off searching eBay now for a reasonable set! Are are there any aftermarket’new’ sets worth trying?
1992 90 Exported
2016 L405 4.4 AB
Post #719935 17th Jun 2025 3:11pm
Thumbs Up Thumbs Up Thumbs Up
Post #719967 18th Jun 2025 2:25am
Andyyav
Don’t suppose anyone knows the fixing bolt sizes for a set of deployable steps?
I’ve found a set of steps without fixings, JLR were only interested in selling me a complete kit 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #720110 20th Jun 2025 7:47pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
the problem is you need one 'magic' bolt for lh rear hinge.
Post #720116 20th Jun 2025 9:21pm
Andyyav
now I'm intrigued! tell me more about magic bolts!! 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #720124 21st Jun 2025 8:31am
