![]() | Home > Technical (L322) > Trans Failsafe Prog |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
You have the ZF 5HP24 transmission
Would be worth checking the fluid level, especially if you have an issue when the transmission is cold that subsequently disappears once it warms up
The TRANS. FAILSAFE PROG message can be caused by a number of things not directly related to the transmission e.g. low battery voltage or a faulty transfer box shift motor potentiometer. The error code should be stored as a P code in the transmission controller, so if you get the codes read this might help with the diagnosis
I’ve never heard of that before. How sure are you that it was 1st gear? The default failsafe gear for the 5HP24 is 4th. The transmission can, however, get 'stuck' in lower gears if the fluid overheats. Phil |
85targa Member Since: 03 Mar 2025 Location: London Posts: 2 ![]() ![]() ![]() |
Thanks for getting back to me, especially with the box type.
