![]() | Home > Technical (L322) > Tdv8 A/C Hose JUE501130 (2-Zone) pin hole, Common Issue? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1868 ![]() ![]() |
Easy repair with a TIG welder |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1048 ![]() ![]() |
And if you don't have access to tig welding 10mm copper pipe x2 compression fitting cut out the damaged section and do a line repair.
nitramsen Member Since: 26 May 2025 Location: Bern Posts: 6 ![]() ![]() ![]() |
Thanks, for the suggestions, I will try TIG first ( My welding skills are not the best).. So if that fails the compression fitting seems like a good fix. My journey repairing the cheapest running L322 Vogue in Switzerland 240kkm model year 2007. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1354 ![]() ![]() ![]() |
I fixed a leak on an old Granada with a product called 'Mends Metal' and it didn't leak for a further 7 years when I sold it. Worth a try? |
