Home > Technical (L322) > front cv boots split
bastion
Have got both outer boots split. Is it a pig of a job to fit new ones?
Post #720531 29th Jun 2025 11:56am
pjw888
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
If you have access to a press, no. Mine was split. The shaft and hub are interference fit and are tight as £$%^. I have read on the forum, preople braking pullers Etc. I took mine to local specialist. He did the job but on doinso, broke their approved JLR tools. I hope this helps.
Post #720557 29th Jun 2025 5:09pm
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Re: front cv boots split
It depends...
I've just done one of mine, in fact ended up doing the whole CV joint as I'd left the boot too long.
This was essential:
https://www.ebay.co.uk/itm/167566125178?_s...R6aQldnvZQ
remember to buy some M14 nuts to fix it to the wheel studs.
This was useful as my splitter was far too small/weak for the job:
https://www.amazon.co.uk/US-PRO-Hydraulic-...amp;sr=8-4
Post #720687 2nd Jul 2025 12:45pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Also need a heavy duty tool like this to crimp the retaining clip on. Needs to be good and tight as the boot isn't overly pliable and it gets pulled around when steering. If it leaks or comes off the cv joint grease escapes and before long you're starting again. Notoriously difficult to make seal, but that might be from not using the right tool?
Chris
Post #720702 2nd Jul 2025 4:53pm
NDT
agreed - I bought one of those and it made a big difference.
Post #720876 5th Jul 2025 3:20pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
I've just completed the job. I used aTITAN TTB653SDS 5.9KG ELECTRIC SDS PLUS CHISEL / DRILL. It was only £60 and they popped straight out using this. I also removed the front ball joints using it. It's great for anything where you need a percussion action.
 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #720918 6th Jul 2025 3:03pm
PDC
I also used this for the CV boots from eBay at £12.00 It tightens with a spanner so you can really clamp on the clips. Just remember not to over pack the boots with too much grease!
CV axle Boot clamp Tool Kit For Toyota Lexus OEM 09521-24010 from eBay. 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #720919 6th Jul 2025 3:10pm
Taylor24
Off topic, but how do you keep your car so clean? All my hubs and arms have surface corrosion on them
Post #720994 7th Jul 2025 9:23pm
PDC
I’ve only just finished replacing pretty well everything that you can see. I did also primer and top coat all of the new parts and then waxed them. Hopefully it will still look like that in a few years time. Razz 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #720995 7th Jul 2025 9:32pm
