Home > Technical (L405) > Restricted Performance on Startup
gholdsworth2000
United Kingdom 2015 Range Rover Autobiography SDV8 Fuji White
Hi
My 2015 SDV8 L405 has developed a fault where every time I start up it goes straight into Restricted Performance.
If I plug in my generic OBDII scanner it comes up with no codes, but doing a reset (i.e. Clear Codes using the reader) takes the car out of Restricted Performance and it drives faultlessly until the next time I start it, when I have to repeat the routine.
It feels like one of those little Range Rover quirks which someone may have come across before...Any ideas?
Thanks!
Post #720566 30th Jun 2025 12:00pm
bigdave
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
Id take a look at the battery first off.
It may be on its way out and these bad boys do not like weak batteries.
Just a thought.
Dave
Post #720573 30th Jun 2025 1:48pm
Your scanner could be clearing a fault that is not shown..
I'd also suggest the battery as first port of call then maybe get the codes read by a garage who has the right equipment ..... Thumbs Up Pete
-Click here for Thread-
Post #720599 30th Jun 2025 11:05pm
gholdsworth2000
Thanks guys,
As the car had only been used for my 15 minute commute lately, I took it for a longer run down the motorway and the problem has disappeared, so I suspect the battery just needed a good charge.
Post #720640 1st Jul 2025 5:40pm
