![]() | Home > Maintenance & Mods (L322) > Brembo caliper bolts - any tips for removing? |
NDT Member Since: 03 Apr 2018 Location: Bedfordshire Posts: 106 ![]() ![]() ![]() |
I've tried heat, penetrating oil and an air impact wrench... |
Bardley Member Since: 01 Jan 2025 Location: Hertfordshire Posts: 31 ![]() ![]() ![]() |
...and I'll add my bullet point.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
Try some Blaster 16-PB used it on some brake connectors that were rusted up and obviously delicate they released easily after two days soaking. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
https://www.screwfix.com/p/makita-dtw1002z...gLT9fD_BwE
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1821 ![]() ![]() ![]() |
This. It may not be obvious to the uninitiated, but better tool access makes a world of difference! Great tip! ![]() EDIT: He means the Steering Wheel ![]() ![]() ![]() |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 589 ![]() ![]() ![]() |
soaked with gt85(doesn't dry up as quick as wd40 i found) left for a day or so and breaker bar |
I think the factory caliper bolts come with loctite applied….
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 200 ![]() ![]() ![]() |
A retired mechanic neighbour swears by Plusgas as the best penetrant and it's all he uses now restoring old cars. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
krzysmaxi Member Since: 26 Jun 2021 Location: Bishop's Stortford Posts: 28 ![]() ![]() ![]() |
Maybe this will help someone:
#2 for Plus Gas V6 Vogue - “Less is More” - less to go wrong! |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
Another for Plusgas, I also love the Homebrew as detailed 50/50 Acetone/ATF.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 547 ![]() ![]() |
Liquid brake cleaner and diesel in a 50:50 mix works very well I've found.
