![]() | Home > Technical (L405) > Digital instrument panel stopped working (speedo etc) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
I know you think it's not the battery but checking the batteries is the best and cheapest way to start.
Melvin Member Since: 14 Nov 2021 Location: UK Posts: 13 ![]() ![]() |
Good point. Thanks for the suggestion, Haylands. I'll check them! |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1508 ![]() ![]() ![]() |
Check your earth points too. They do funny things when they corrode |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16380 ![]() ![]() ![]() |
JLR stopped them in 15/16my Peter... Moved to a condenser arrangement... ![]() |
That makes life easier.... or do they fail as well...? |
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1406 ![]() ![]() |
Well I have a second battery on MY 2018 2018 SE SDV8 4.4 Byron Blue |
Hello,
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1326 ![]() ![]() ![]() |
Try putting both chargers on at the same time. I did this once to overcome the resistance in the battery and then it carried on charging. |
Replace both batteries I bet they are original so 7 years is about right for a change 2018 SE SDV8 4.4 Byron Blue |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2735 ![]() ![]() |
You might have to connect an extra battery to the car for the charger to see enough voltage to start charging, then disconnect the extra battery after a few minutes. L405 D350 SE Carpathian Grey D5 19" rims |
Thanks for all the advice, everyone. Much appreciated.
Do you have a 2nd car and jump leads? connect with terminals under bonnet should easy be enough to open tailgate.
Yep, I've got another car and jump leads so I can do that. Do you think that that's a better option than connecting the new battery to the terminals under the bonnet?
I would do it first while you are waiting battery so you can open tailgate. 2018 SE SDV8 4.4 Byron Blue |
