Home > Technical (L405) > Burning smell when accelerating
tomthespark2011
Hi fellas,
2017 FFRR 5.0 SVR
Runs like a Swiss watch, no issues....until i accelerate with gusto.
It idles, accelerates and stops 100%, but after you accelerate hard or with a bit of sprite, theres a faint but definitely noticeable smell of burning in the cabin that soon disappears once you go back to a 'normal' throttle.
It smells like burning engine oil. You know if you dropped some oil on an engine block that was really hot. That kind of smell.
No obvious leaks under the hood, no issue anywhere infact that i can see.
Any thoughts?
Thankyou
Post #720963 7th Jul 2025 7:29am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
I have a similar issue on my SDV8, I am told it is probably an oil leak in to the V possibly from a rocker cover gasket.
I am also told to investigate is a big job as a lot of stuff has to come off. letters not necessarily in the right order
Post #721004 8th Jul 2025 7:35am
Mr Tee
Noticed mine does the same . 2019 SV AB Dynamic Scafel Grey
Post #721005 8th Jul 2025 8:23am
Happy to say that I've not had that.....................................yet! Mike - MPx
Post #721006 8th Jul 2025 9:09am
tomthespark2011
looool. This is clearly a common issue that nobody is bothered to fix Laughing Laughing Laughing
Post #721112 10th Jul 2025 8:31am
madasmad
United Kingdom 2019 Range Rover Autobiography SDV8 Baltic Blue
Most likely the oil cooler or the gasket for the oil cooler. I have both done at different points on my MY20 4.4 SDV8. It is a long job as a previous poster has said. 2019 Autobiography SDV8 Byron blue/black - current
2016 Vogue SE SDV8 Santorini Black/Ivory - sold
2009 RR Sport TDV8 HSE - sold
Post #721304 15th Jul 2025 10:54am
