Home > Technical (L405) > Electronic Parking Brake (EPB) Error on dash - Yet it works
Ashmyster79
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Good morning,
I hope someone can help before I go and get ripped off. My drivers side rear EPB motor went bad so I replaced it. It was a 10 minute job however the re-calibration or actually getting it to show no errors on the dash doesn't seem to want to be as quick if at all.
The EPB works (although I am too scared to use it as it clamped on and I ended up scoring badly my brake disc moving forwards nd back) it goes up and down as it should however, I have the orange warning on the dash. No matter what I do to try and erase it, it wont go. I plug a reader into it and it shows no errors, so wondering if the error is embedded somewhere (I'm not a mechanic).
The car had its MOT & Service yesterday. They report as I had told them the error is there yet the EPB works so it passed on that basis. However I need to get the code removed. IS it a simple battery, unplug, leave for half an hour, and it will reset, or is there a process I need to follow to remove the error code? I have been on YouTube for months trying every process suggested, and this has returned me no reward. If the motor and everything work to enable the handbrake to engage and disengage, why do I still have errors? Could it be connected to something else that is not working?
A few months back, when I got out of the car (engine running and lowered) I got back in and my partner said the seat moved and was a crunching sound. The cigarette lighter socket in the front did work but no longer works. Cruise control does not work (I assume this is to do with the braking error)
Could it be a fuse if so where would this be?
Can I disconnect the battery (assume this is in the boot)
From the MOT, I had a couple of advisories
Nearside front brake pad wear sensor rubbing on the driveshaft
Nearside front ABS sensor rubbing on driveshaft
Could these be the reasons (not sure if this will affect the handbrake, which is on the rear).
Any help or suggestions? Like I say, the EPB works, just the error code needs removing.
Oh anyone want to buy a L405 (£12k) Wink Current Cars
L405 Range Rover Vogue 4.4 Diesel
Previous cars
Lamborghini Gallardo
2006 Range Rover Vogue 4.2 V8 Supercharged Petrol
1996 Williams Clio 2
Aston Martin V8 Vantage
Bentley GT Continental
Porsche Cayenne 4.5s
4.2 V8 Supercharged Range Rover
Porsche Boxster 3.2s
Ford Kuga
Nissan 350z
BMW 316
Porsche Boxster 2.5s
Golf 2.8 VR6 Highline
Renault Clio 16v
Vauxhall Nova GTE
Post #721303 15th Jul 2025 8:57am
Kot
I would start with fixing your MOT advisories, then ensure you have a code reader that can clear DTC's.
Then rescan! 2018 SE SDV8 4.4 Byron Blue
Post #721315 15th Jul 2025 1:37pm
Ashmyster79
EPB Error - update
So I purchased an Icarsoft to go deeper into the issue I am having with the EPB, where it works, yet I have the error on the dashboard (Park Brake Fault).
It seems the issue is the right actuator, which I have changed, seems to be showing a fault even once the code is cleared. Clear the code on the Icarsoft, and instantly I get a bong sound, which I understand to be the car telling me the fault is still there. Operationally, it works, no issues; however, it's a permanent fault, so it seems.
Does anyone know how I can clear a permanent code, or is there a process to reset this? I did think about disconnecting the battery for an hour and plugging back in or stripping down (again the actuator). Any useful tips that might enable me to remove the permanent code? As I said, it all functions well, just the irange lights on the dash are not good for me as I am trying to sell. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #722000 28th Jul 2025 6:55pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
What is the code?
Post #722002 28th Jul 2025 8:00pm
Mikey
There is a brake caliper assembly replacement routine on higher end diag equipment. Should be done when either caliper or motor are replaced Thumbs Up
Post #722004 28th Jul 2025 8:34pm
Ashmyster79
hmallett wrote:
What is the code?
It hasn't given a number, or I could see a number it just says State: Permanent Right actuator. Normally, you do see a code but nothing. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #722018 29th Jul 2025 8:28am
Ashmyster79
Mikey wrote:
There is a brake calliper assembly replacement routine on higher-end diagnostic equipment. Should be done when either calliper or motor is replaced Thumbs Up
Is this a RR main dealer thing or something I can do myself?
I had replaced this side before, and it worked for months, no issues, no error messages, but then something happened, I can't remember what, but I needed to replace it again, which I did. Maybe there is something else going on, but the main dealer isn't what I want to be doing, but I feel I am being pushed that way.
It was a simple replacement project, 10 minutes, how hard can it be? It's just a motor swap-out.
Maybe I will do the whole process again, strip it down, take it off, and replace it with another motor. Annoying thing is it all work,s just the dash has the warning on all the time. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #722019 29th Jul 2025 8:33am
Ashmyster79
EBP Fix Update
After 9 months, it's finally fixed. I bought an Icarsoft V2.0, which has the service mode to recalibrate the EBP. Howeve,r I didn't know this function was there. I went into the usual ODB/Diagnostics functio,n tried to clear the codes it just kept looping round to clear but then would reappear instantly. I took the actuator off (again) and put the old one back on, hoping this would clear it or not make it worse.
Anyway, test drive day later, and it's smoking out of the rear right as it did before (EBP clamped on). Took it home (2 min drive) and it was almost on fire. ffs so I took that off again and replaced the original replacement one back on (confused so am I).
This time it went on OK, and I made sure all was tight as could be. I jumped in the car (neverson in this as the car was on the scissor jack with a trolley jack and axle stand supporting).
Plugged in Icarsoft, found the service section from a YouTube video and all the calibrations were there (5 in total). Not really knowing which ones to do, I did them all. Long story short whatever I did cleared the codes and errors from the dash. Car is smooth like butter and the cruise control is now working...... perfect.
Icarsoft, help on here and youtube saved me a few hudred I feel so well worth it.
Thank you to all the comments..... it helped. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #722713 12th Aug 2025 7:15am
supershuttle
I don’t actually know if I was “ripped off” my indie said some related bits needed replacing so I told them to get on with it. I had no warning lights or smoke possibly because I never used the EPB just left the car in park. I do use it now (when I remember) and of course it works perfectly. Glad you got yours sorted, Geoff
Post #722718 12th Aug 2025 8:44am
