![]() | Home > Technical (L405) > L405 GAP key programmjng |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 190 ![]() ![]() ![]() |
Hi, first question on my new to me L405 !
Thanks for that Zebedee, I couldn't see the menu on the Gap Tool but wasn’t sure where the menu is as I’ve only programmed L322 keys in the past and seemed to find the correct menu back then. Do you know which menu it is although I’m guessing it may be locked out as you say, the car is a 2013 and I was under the impression Landrover started locking them out after this model year. |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409 ![]() ![]() ![]() |
Thanks Zebedee for the info that seems like a good place to start, I checked the manual and it made reference to having an already programmed key and sending the ecu info to GAP to allow the preparation of a file which has to be repeated twice, not sure what this means but I will try and follow the instructions in the manual. |
