Home > Maintenance & Mods (L405) > After another favour
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Just fitted some deployable steps to my 2016, (it had them from the factory but they had been removed) I’ve a hole for a bolt and a gap for a spacer (I assume) each side but there’s no thread, I’ve asked LR main dealer but they couldn’t help apart from trying to sell a fitting kit
Would anyone be able to take a picture of their fixing bolts so I can see what’s what?
Should there be a spacer between the step bracket and subframe hole?
 1972 Series 3 full of character
1985 90 pick up went anywhere
1992 90 Exported
2007 L322 that was an experience
2010 D4 more versatile than a Swiss army knife, now gone
2011 L322 4.4 VSE traded in
2018 L405 4.4 VSE Sold a wrong un
2016 L405 4.4 AB
Post #721340 15th Jul 2025 6:20pm
I was hoping someone else would step up, but hey ho..... I took some pics but most of mine seems to be hidden behind a bit of plastic -
There's something the in front of the brackets -
Does the step need to be deployed top see what you need to ?
I should probably try deploying mine, they've been switched off for years..... Confused
Post #721417 16th Jul 2025 7:07pm
Andyyav
Thanks Alistair it really is appreciated, I’ve not got the plastic ‘shield’ in your picture something else I better look into!
The step wasn’t deployed when I took the picture, I was laid under it doing the gearbox filter, it’s the furthest point of the mounting bracket away from the door if that makes sense 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #721419 16th Jul 2025 7:33pm
My first pic was taken from the front wheel looking backwards. I'm not sure I can provide anything more useful without starting to dismantle things
Post #721422 16th Jul 2025 7:50pm
Did you watch this ?
Post #721424 16th Jul 2025 7:54pm
Andyyav
Thanks for all your help Bow down
I hadn’t seen the video I’ll see what fixings they use 1972 Series 3 full of character
1992 90 Exported
2016 L405 4.4 AB
Post #721446 17th Jul 2025 12:03pm
