Home > Technical (L322) > 4.4 TDV8 oil leak from bottom end.
BAZ8046
United Kingdom 2012 Range Rover Westminster 4.4 V8 Santorini Black
Hi,
Have been chasing a minor oil leak on the L322 for a while now.
It's not massive but drips off the joint between the engine and gearbox under the starter motor.
When I first got the car I presumed this oil leak was from the top and there was a small leak from the oil cooler and turbo feed pipes.
These have now been done a while ago and the top end is dry. (have checked twice for my own sanity!)
As far as I can make out this leak is either rear of sump or rear main seal.
I did drop the starter motor last weekend so I could get a better view.
The only thing to note was that the 8mm bolts on the back of the sump were not fully torqued up and took about a quarter of a turn.
I was hopeful that this would help but the leak is still the same.
For obvious reasons I'm not in a rush to take the sump off or the gearbox out!
If anyone has any ideas, or has come across similar before, it would be greatly appreciated.
 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #715253 31st Mar 2025 11:17am
Rove Ranger
England 2012 Range Rover Vogue SE 4.4 V8 Orkney Grey
Watching with interest - I fear I have the same.
And a powersteering weep, somewhere...
At least it's providing some rust-proofing to the front subframe.
Post #715263 31st Mar 2025 12:24pm
BAZ8046
Yes that's true, will definitely help with the rust-proofing Very Happy
I also have a wet power steering line but it's not dripping as yet.
This will be the next job on the list although I think it is the crimped fitting on the end of the line. 2012 TDV8 4.4 Westminster Santorini black
2002 Defender TD5
Post #715271 31st Mar 2025 1:49pm
pcourtney
England 2011 Range Rover Vogue 4.4 V8 Sumatra Black
once you have cleaned as much old oil off as possible, use could try some UV Oil Detection Dye
ebay £6 quid ( but you will also need UV torch if you don't have one )
10 ml UV Leak Detection Dye For Fuel Oil Petrol Diesel Fluid Leak
Post #715272 31st Mar 2025 2:24pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Looks like engine oil, so my guess would be crankshaft rear oil seal.
Post #715274 31st Mar 2025 3:28pm
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
I have a similar issue, top end, cooler turbo feed etc bone dry. Inspected as far as possible around turbos also dry. Concluded rear main / rear of sump the cause. Don’t think going to strip out - it’s not bad enough yet. However, I have bought this from eBay https://www.ebay.co.uk/itm/166394376868, haven’t tried it yet, has any one else ? Thinking of adding at an oil change & see how it goes albeit a little apprehensive in case it causes a catastrophe!
Post #715284 31st Mar 2025 6:58pm
BAZ8046
Thanks all, the UV dye is a good shout, I’ll get some ordered for the weekend.
They are not the easiest vehicles for access to see what is going on.
I had a good search for threads on oil leaks but didn’t find much for the bottom end.
I’ll let you know how I get on. 2012 TDV8 4.4 Westminster Santorini black
2002 Defender TD5
Post #715287 31st Mar 2025 7:20pm
kevinp
I have exactly the same drip. Hope you find the cause.
Post #715300 31st Mar 2025 8:41pm
dhallworth
Looking at the oil around the flywheel and inside the bell housing where you've removed the starter, I'd be thinking it's the rear main oil seal also known as the rear crankshaft oil seal.
The genuine part from Land Rover (LR29001) is £128 so not overly expensive but that will be a massive job to fit which would involve removing the gearbox and transfer box from the car before removing the flywheel.
I hope I'm wrong and it's something more straight forward though.
Post #715301 31st Mar 2025 8:48pm
dhallworth
Double post for some reason! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #715306 31st Mar 2025 9:42pm
Fatzo
France 2011 Range Rover Vogue TDV8 Ipanema Sand
I think I have the exact same problem, rear cranshaft oil seal.
With also some hot oil stink....
Will have it fixed start of next month, but the gearbox should be removed....
Pretty tough job
Post #715307 31st Mar 2025 10:08pm
BAZ8046
Thanks, yes I've a feeling you are right David and the prime candidate is the rear main seal.
Unfortunately this would be a workshop job for me as removing the gearbox at home is not practical.
If I read the WSM right you also need to remove the trigger wheel which is another complication without the right kit to re-install.
The sump also gets removed and replaced during the process so that would be renewed at the same time.
I'll see if I can get a camera in to try and get it confirmed. 2012 TDV8 4.4 Westminster Santorini black
2002 Defender TD5
Post #715325 1st Apr 2025 9:53am
BAZ8046
There was an interesting video posted by Christian and Vera over the weekend.
This seems to be a similar leak but turned out not to be the sump or real main seal.
Have added some UV dye this weekend so at least this should confirm how high up the oil is coming from.
I've checked again with a mirror and the turbo feed and cooler area is definitely dry as well as the rear of the heads.
It is slightly wet just at the back of the V but doesn't look fresh and is in an area that is hard to clean whilst changing the cooler.
It's hard to get any photos but I've had a go, will report back on the results from the dye.
2002 Defender TD5
Post #715691 7th Apr 2025 9:01am
jimbob292
I wouldn't beat yourself up too much.
I had the same, it was like a river of oil at the start, the oil cooler was leaking & O rings, I tried to clean as much as possible from around the back & above the bell housing. With Jizer, left it for a few days, again a weep of oil, cleaned again, still a slight dribble, and this has been a month now, it was that bad it was flowing down the side of the engine and tracking over the turbo.
If it persists I will borrow a camera to have a look at the trigger wheel location.
UV dye is a good solution, used it a few times to trace out issues, also with DP spray, once the part is clean spray the developer, beings it’s a white spray, it clearly shows where the oil is oozing from.
My old 3.9 V8 had a crankshaft oil seal blow, my god that’s a flow of oil; it wasn't fun, bench pressing a ZHP4 on a trolley jack Laughing
Post #721650 21st Jul 2025 6:53am
