![]() | Home > Maintenance & Mods (L405) > Offside Boot Trim Removal - the buttons part! |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 257 ![]() ![]() ![]() |
Take the black plastic trim off and it just pulls off |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2770 ![]() ![]() |
How is the black plastic trim removed without damaging it please? L405 D350 SE Carpathian Grey D5 19" rims |
It has two good clips, pull it out and it’s comes free, it’s also tucked under the boot rubber.
Thanks. I had tried a couple of times but each time thought that clips were about to break. Mine's a MY21 but I'd be surprised that they've changed since the first L405. L405 D350 SE Carpathian Grey D5 19" rims |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 280 ![]() ![]() ![]() |
Do the buttons easily pop out? Is there a specific place to prise from i.e. from the bottom? The black bit looks quite fragile and I dont want to damage it? Actually to get the trim off do I even need to pop out the button first or can i just unplug it once ii have pulled the main trim off? _______________________________________________
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
There's enough slack on the switch loom to remove the trim and then disconnect, or if you want to remove it, i think each side at centre position is where to push in the metal retaining tangs L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
