![]() | Home > Technical (L405) > Instrument Cluster software upgrade through SDD |
ss10 Member Since: 05 May 2025 Location: Reston, VA Posts: 39 ![]() ![]() ![]() |
Anyone know if the cluster software can be upgraded using SDD?
Thank you. Do you recall which special function you used for it? |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
I think I selected IPMA (image processing module A and it found a newer version, I did mine to extend the diesel / oil dilution percentage value from 6% to 7%. If you go through the guided fault finding menu tree relating to instrument display as if you have a fault or issue it will get you to where you need to be. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
