Home > Technical (L322) > EAS fuses
davidrosenbloom
2009 Range Rover HSE 4.4 V8 Chawton White
EAS fuses
Seeking help for EAS.
There are three fuses for the EAS; one 5 a in front and one 20 amp in front and one 5 amp in rear.
My question is does the EAs computer use the 20 amp or is that a compressor fuse? Cant imagine that compressor runs on a 20amp it would need more juice. I cant find a wiring diagram which Id take if anyone has one.
Dave
09 FFRR
12 FFRR
Post #721744 22nd Jul 2025 10:02pm
GraemeS
Australia
The 20A is the main power supply to the EAS ecu, one 5A is the feed-back from the compressor relay so that the ecu knows that the relay contacts are closed and the other 5A is the ignition sense to know that the ignition is on. Removing the 20A fuse prevents the valves in the valve blocks from operating.
I'll dig out the wiring schematic later although IIRC it's available from the wiki. L405 D350 SE Carpathian Grey D5 19" rims
Post #721748 22nd Jul 2025 11:16pm
