|  | Home > Maintenance & Mods (L322) > New high pressure fuel pump on the way |
| toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 318    | Will you be fitting it or a garage? If you, I would be interested in your take on it, thanks. 2012 Vogue TDV8 in Aintree green over sand | ||
|  29th Jul 2025 2:52pm |
| JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 310      | I'll get my local Indy to do it. Although it doesn't look a big job, high pressure fuel squirting all over the place if I disconnect the wrong pipe at the wrong time, means that I'd be happy to pay an expert.
|  29th Jul 2025 3:04pm |
| Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 215      | What does it sound like and where under the bonnet is the noise most noticeable please? 2012 4.4 TDV8 Vogue Santorini black ivory leather | ||
|  29th Jul 2025 9:14pm |
| JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 310      | It’s a sort of rattle - most noticeable inside the car in the first few mins of driving. I thought it was a dodgy alternator bearing, but the Indy said it’s definitely the high pressure pump.
|  30th Jul 2025 6:17am |
| Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 215      | Thanks 2012 4.4 TDV8 Vogue Santorini black ivory leather | ||
|  30th Jul 2025 9:07am |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | My injection pump got really noisy so I put some good injector cleaner in the tank and it has been quiet ever since. Worth a go? | ||
|  30th Jul 2025 10:53am |
| ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 285      | Out of interest what injector cleaner did you use? I am sceptical as to whether those things actually work?   | ||
|  30th Jul 2025 11:15am |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364      | Millers Eco Max. Absolutly stinks, so wear gloves!! | ||
|  30th Jul 2025 1:46pm |
|  30th Jul 2025 1:55pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
