Home > Technical (L322) > howling / frequency noise at motorway speed
Jimnic007
United Kingdom 2012 Range Rover Vogue TDV8 Nara Bronze
I was on the motorway a couple of days ago in my 2012 4.4 TDV8 and it was a very hot day. Having done around 80miles at motorway speed, the car starting making a reasonably loud howling noise from what sounded like the lower, frontal area. It stopped when dropping below (say) 50mph, but above that it started up again. It wasn't present all the time, but for long periods it was.
I looked underneath on arrival and couldn't see anything flapping around and it didn't do it on the return journey today, in cooler temperatures.
The car has been fully serviced within the last 3,000miles, including a gearbox service/flush.
Does anyone have any idea what could have caused this, or was it just a strange frequency/wind noise?
Thanks,
James
Post #722857 14th Aug 2025 4:50pm
JayGee
Rad fan cutting in to aid cooling during a DPF regen? 2012 TDV8 Vogue (L322)
Post #722863 14th Aug 2025 6:50pm
Jimnic007
Could be, it certainly felt like something was whirring away at a high speed. Is that normal and anything to worry about?
Post #722864 14th Aug 2025 6:53pm
JayGee
Not normal as there should be plenty of airflow at M-Way speeds through the radiator without needing fan assistance. Maybe worth investigating further. 2012 TDV8 Vogue (L322)
Post #722865 14th Aug 2025 7:05pm
CS
A similar noise on my L405 was diagnosed as a wheel bearing in need of replacement. Only Range Rovers since 1988
Post #722871 14th Aug 2025 8:59pm
steve k
United Kingdom 2003 Range Rover HSE Td6 Giverny Green
It's a 5.0 petrol? so if I'm correct there is no regen on petrol cars?
Sounds like viscous fan is getting tired. At higher RPM if its starting to get 'tired' it may be unable to keep slipping. However, if you are using the A/C first check that the electric cooling fan at the front is working Current: 2003 TD6 HSE
2004 Vogue SE 4.4
Previous: 1993 Classic 3.9
Post #722874 14th Aug 2025 9:54pm
Rambles
Some folk find a droning noise comes from an aged scuttleboard
If temp related, have you tried whether turning AC off makes a difference?
Whether you select cold or normal air through the face level vents ?
Post #722876 14th Aug 2025 9:58pm
Jimnic007
Thanks all, I will investigate the suggestions above.
It is a TDV8 for clarity, I just hadn't updated my profile recently.
Post #722885 14th Aug 2025 11:38pm
